2003 Dodge Grand Caravan Steering Whine Fix
ROCCO57
38,000 miles, 3.8 litre
In 2004 the power steering hose was replaced due to a Dodge recall.
Just latley the car sounds like it is out of power steering fluid, and it is not. The noise comes and goes, sometimes it stops after a few minutes, and sometimes after driving long distances, it returns.
My mechanic has checked everthing, and cannot find the problem.
Thanks
Jan 27, 2007 at 4:03 AM
SERVICE WRITER
  • 9,123 POSTS
Are you saying it is whining when turning?
Jan 27, 2007 at 4:04 AM
ROCCO57
yes
Jan 27, 2007 at 4:22 AM
SERVICE WRITER
  • 9,123 POSTS
Was that recall in regards to making the power steering return hose longer? We just did one 2 weeks ago and cured it. I don't believe it was a recall however, now that I think about it. As a matter of fact, do you have a little shudder when turning?
Jan 27, 2007 at 4:26 AM
ROCCO57
I don't remember the specifics, just got it done when I got the recall card
Jan 27, 2007 at 4:28 AM
SERVICE WRITER
  • 9,123 POSTS
No matter, I'll send you the TSB, it wasn't a recall. I had a customer that had the same truck, same complaint. I felt the shudder that she didn't. did the TSB, and both probs were solved. If you have jack stands, you can do it. You don't need the dealer for this. Your regualer independent can do it if you can't. Check your email in 5 mins.
Jan 27, 2007 at 4:34 AM
ROCCO57
No shudder
SERVICE WRITER
  • 9,123 POSTS
Well for what it matters, this took care of the whine on the one I did.
Jan 27, 2007 at 4:44 AM
Suggested Repair
Have a shop perform the power steering return-hose TSB that lengthens the return hose. The expert reported that procedure cured similar intermittent whine, even though this owner has no steering shudder.
Conversation Summary
The owner of a 2003 Dodge Grand Caravan reports intermittent power steering whine when turning despite adequate fluid. A hose was replaced after a 2004 recall notice, and a mechanic found no cause. The expert identified a related TSB, not a recall, to lengthen the power steering return hose and said it cured whine and shudder on a similar vehicle. The owner has no shudder, but the expert noted the TSB still fixed the whine in that case.
