2003 Dodge Caravan no power to coil pack/no spark
GREASY HANDS
  • 2003 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 11,500 MILES
I replaced, the coil pack, the plugs, the plug wires, the crank sens, and the pcm. And still I have no power or spark to the coil pack or plugs. Is there any thing else that would cause this, other than the ecm?
Wednesday, October 20th, 2010 AT 11:59 AM
JDL
  • 16,098 POSTS
Before you replaced the crank sensor, did you check the sensor circuits at the wiring connector? Primary voltage to the coil--injectors--02 heater circuit, comes from asd relay. I'm not saying the relay is faulty, I'd have to check wiring circuits, voltage and ground. Also, your cam sensor could cause an issue. I can't tell much without testing?
Wednesday, October 20th, 2010 AT 1:17 PM
