1994 Dodge Caravan Ignition problems
17,022 MILES • 6 CYL • FWD • AUTOMATIC
PAPPY1958
  • 8 POSTS
Ok, back again, I will have o wait till tomorrow to check pressure in fuel system, but so far I've changed the coil pack, and the timing chain. STILL WILL NOT START! now could it be as simple as maybe the ASD relay? and How do I check this? the connectors on the right and left have no resistance, but there is nothing when I connect one to the top or bottom connector, they are numbered 65,66,67,and 30. 4 connectors 66, and 65 are R&L, and 67 and 30 are Top & Bottom. where should I have flow(no resistance) and no flow? also, is there any other relays that would stop the starting of the motor? Thanks,,,, Dave pappy1958@aol.com
Oct 31, 2010 at 9:48 AM
  • 110,248 POSTS
HI:
This is a new posting, so I don't know what all is going on. Are you getting spark to the plugs?
Nov 1, 2010 at 1:19 AM
PAPPY1958
  • 8 POSTS
Ok,,, here is what's going on,,,driving, and slowing for a turn into development, van motor quit. it's a dodge caravan 3.3 94 model, so I have changed out the DIS coil pack, the Timing Chain, the Crank sensor, and the computer. Still NO Spark to the Plugs. I put a noid light on the injectors as was suggested,,,NO Light. I'm at my end, I have no other ideas what this could be. I Need Help!,,, Thanks,,,,Dave,,,,, pappy1958@aol.com
Nov 1, 2010 at 8:44 AM
  • 110,248 POSTS
It could be the ASD. Have you checked the relay in the power distribution box under the hood?
Nov 1, 2010 at 12:55 PM
