2003 Dodge Caravan EVAP Codes
NBHS1989
My 2003 Dodge Caravan has the engine light on. the codes are PO442, PO 455, PO 456. I had the fuel filter changed yesterday and my car passed the smog test. My car for the last week has been stalling. While drving on th hwy it has low power. While driving in the city the car just stalls and shuts down. It definately has lost power. I was wondering if it could be the fuel pump? Any suggestions?
Aug 7, 2006 at 6:36 AM
MIKEYBDMAN
  • 623 POSTS
[quote:e08ff7037e="NBHS1989"]My 2003 Dodge Caravan has the engine light on. the codes are PO442, PO 455, PO 456. I had the fuel filter changed yesterday and my car passed the smog test. My car for the last week has been stalling. While drving on th hwy it has low power. While driving in the city the car just stalls and shuts down. It definately has lost power. I was wondering if it could be the fuel pump? Any suggestions?[/quote:e08ff7037e]
These faults are telling you that you have an evaporative system leak. Here is what the book suggests as possible problems.
SET CONDITION
If there is a leak larger than 0.040 inch and smaller than 0.080 inch in the evaporative system.
POSSIBLE CAUSES
Good trip equal to zero
Verify evaporative emission system leak
Evaporative emission leak detection
EVAP purge solenoid leaks/stuck open
Intermittent LDP monitor failure
Aug 7, 2006 at 7:17 AM
Suggested Repair
Diagnose the evaporative emissions system for a leak larger than 0.040 inch and smaller than 0.080 inch. Check the EVAP purge solenoid for leaks or sticking open and the leak detection pump monitor for intermittent failure. The expert did not confirm a fuel pump fault.
Conversation Summary
The owner of a 2003 Dodge Caravan reports check-engine codes P0442, P0455, and P0456, a recently replaced fuel filter, a passed smog test, stalling, highway power loss, and shutdowns in city driving, and asks whether the fuel pump is at fault. The expert says the codes indicate an evaporative system leak and lists possible causes including verifying the leak, a leaking or stuck-open EVAP purge solenoid, and intermittent leak detection pump monitor failure.
