Ignition off disconnect EVAP purge solenoid
located on lower right side of engine compartment near radiator
disconnect PCM connectors
PCM located on left side of engine compartment near front of battery
measure resistance of dark blue /white wire and terminal # 68
if more than 5 ohms
repair open in the dark blue /wire between solenoid and PCM
measure resistance of dark blue wire /white and ground purge solenoid connected if less then 5 ohms repair short to ground in the dark blue/white wire
check resistance of dark blue/brown wire between solenoid
harness connected and PCM pin #70 harness connected if 5 ohms or more repair an open in the dark blue/brown wire
SPONSORED LINKS
Sunday, June 8th, 2008 AT 7:58 AM
