2002 Dodge Caravan Engine warning indicator on
82,615 MILES • 6 CYL • FWD • AUTOMATIC
CLEMWATTS
When I started my van yesterday morning, felt a vibration, which continued for a while. As I drove on it was smooth again. But whenever I slowed down to probably the 1 gear, the vibrations started again.
Like it was running out of gas or something. I have run the van for about 30kms and now I have noticed a sulphur burning smell inside of the cabin. The engine warning indicator is constantly on.
I know I've got to take it into a Dodge repair shop soon, but would like to have a fair idea of where the problem might be. Will appreciate any help as I would be stranded without my ride.
Thanks
Sep 29, 2009 at 11:29 PM
CH112063
  • 1,320 POSTS
With the check engine lamp on you have made a wise decision. Any number of fuel management sensors, and PCM responses may have failed, causing a lean or rich condition. that is why your smelling strange smells. A sulpher like smell is usually from the battery but it can be from many other parts also. Smart to have it serviced by a dealer. Factory training for a particular car is best. ok
Sep 30, 2009 at 5:48 AM
