Sometimes when I turn the key engine wont crank over. After 3 or 4 times of turning key engine turns over
Saturday, November 28th, 2009 AT 1:40 PM
CH112063
MECHANIC
Many of the switches had problems, including the ignition switch, the switch grounds through the nuetrasl switch on the transmission with a relay.
SPONSORED LINKS
Saturday, November 28th, 2009 AT 9:04 PM
CARADIODOC
MECHANIC
Also, do you hear one clunk from the starter when it doesn't spin the engine? If so, the solenoid contacts are worn. They can be replaced, but most people just replace the entire starter motor. The problem will remain intermittent for a long time, but will get progressively worse.
