2002 Dodge Caravan
JSUMRALL
  • 2002 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 82,000 MILES
Check engine light is on. Had system checked. Problem code was transaxle controll module has fault. Transmission shifts thru the gears fine what could be the problem
Friday, August 6th, 2010 AT 2:11 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you post code in P0xxx format it will help diagnose
Thanks for donate
Friday, August 6th, 2010 AT 2:22 PM
JSUMRALL
Fault # I have is po 700
Friday, August 6th, 2010 AT 3:00 PM
DOCFIXIT
  • 18,828 POSTS
EATX controller has detected a trans fault code. If no other codes present at this time was a intermittent code. Need scanner to erase code and if no reset your good
Friday, August 6th, 2010 AT 3:07 PM
