Hi, it is quite different then the older blend doors that used a cable and lever. In 2002 models it is an electric motor. So it may be out of calibration and not opening properly. The dealer has a DRBIII diagnostic tool that plugs in and re-calibrates everthing, mode, recirc, blend, and control resistors. If it seems different then any other newer model after 99, it may be out of calibration. OK It would probably cost quite a bit. Its an all electrinic system. Good luck, anytime.
Saturday, April 17th, 2010 AT 3:57 PM
