my minivan doesn't starts the engine, so when I check the fuse and relays box the asd relay is making a click sound but whats that relay is for wich part of the engine support it?
Monday, September 29th, 2008 AT 11:39 AM
MECHANIC
Hi:
ASD (Auto Shut Down) The ASD Relay provides power for the coil and other essential circuits. This relay is activated only for a few seconds when the key is first turned on and remains on as long as the PCM receives a crank signal. Is the crank sensor good? If there is no signal from the crank sensor, the ASD will shut down and the car will not start.
