2001 Dodge Caravan Engine knocking.
2001 DODGE CARAVAN
80,500 MILES • 6 CYL • 2WD • AUTOMATIC
AMB0507GIL
Oil filter was damage and all the oil drained from the car. When it was run the connecting rod was broken. Since then the rod, piston, piston rings, rod bearing, and valve have been replaced. Put it all back together engine is still making a knocking noise but just not so loud as before. Im worried about another rod being damage or maybe it is common after replacement. I just dont want to breakdown with my newborn in the car....again.
Jul 11, 2009 at 1:29 PM
  • 31,937 POSTS
HI there,
did you check all the other bearings? cam & over head gear? when you do that much damage to an engine you will have problems other that the failed rod you replaced.
Mark (mhpautos)
Jul 11, 2009 at 2:11 PM
