2001 Dodge Caravan airbag light stays on
MERLIN PERKINS
  • 2001 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 115,000 MILES
My airbag light began acting up, going on and off. It now stays on all the time.
My horn and my cruise control still work with no problems.
I was told by the dealer that, if my cruise control and horn did not work, that it was a problem with my clockspring inside the steering column.
However, since my horn and cruise control still work OK, what is the cause?
Wednesday, June 9th, 2010 AT 9:01 AM
  • 109,885 POSTS
They are correct. The clock spring is the problem if the horn. Don't work. However, in your case, chances are there is a bad sensor or one that is disconnected. Have the computer scanned to identify where the problem is coming from.
Wednesday, June 9th, 2010 AT 12:57 PM
