Hi scott3696. Sounds like you may have a run down battery. Use a cheap digital voltmeter to measure the battery voltage with the engine off and again when it is running. You may have to charge the battery to get it to start but the charger should be turned off when you're making the voltage measurements. We want to know what the van is doing, not the charger.
With the engine off, battery voltage should be around 12.6 volts when it is fully charged. If you find near 11 volts, suspect a shorted cell in the battery. When the engine is running, you must have between 13.75 and 14.75 volts at the battery. If it is still around 12.6 volts, the charging system will be the next thing we're going to diagnose.
Caradiodoc
SPONSORED LINKS
Wednesday, October 23rd, 2019 AT 2:46 PM
