2000 Dodge Caravan Help
SIXVARGAS
2000 Dodge Caravan 6 cyl Two Wheel Drive Automatic
vehicle cranks but will not turn over. It appears to not be getting fuel or spark. What's the best place to start?
Jul 31, 2009 at 6:01 AM
CARADIODOC
  • 34,414 POSTS
"Cranks" and "turns over" are the same thing. Does it or doesn't it?
Both injectors and coil(s) are powered through the Automatic Shutdown (ASD) which is turned on by the engine computer when it sees engine rotation, (cranking or running). It knows the engine is rotating when it sees pulses from the crankshaft position sensor.
caradiodoc
Aug 7, 2009 at 2:53 PM
