2000 Dodge Caravan felt ceiling
82,000 MILES • 6 CYL • FWD • AUTOMATIC
ALFANTA
My 2000 Dodge Caravan felt lined ceiling is peeling off and drooping down on rider's heads. Only 7 years old when this problem started. Apparently the inner ceiling is styrofoam and the glue that hold the felt in place is breaking down. Anyone have a remedy for this problem?
Thanks for any advice
Jul 1, 2009 at 1:10 PM
  • 110,246 POSTS
The only thing I can tell you is that 3M makes a glue for repairing them. However, I believe you need to remove the old foam before using it. In other words, remove the head liner, pull it back, clean the area needing fixed, and then reglue it.
Jul 3, 2009 at 10:02 AM
