2000 Dodge Caravan engine dies when slowing down
BCG
2000 Dodge Caravan V6 Two Wheel Drive Automatic 176000 miles
On occasions my grand caravan will die when slowing down. The check engine light has not come on. I've replaced the plugs, wires, and coil- same thing. Otherwise it runs great. It will do this for a week then it may go a week with no problem.
Dec 1, 2007 at 1:39 PM
  • 75,988 POSTS
Have the idle air control valve, throttle position sensor and EGR check.
Dec 1, 2007 at 7:04 PM
  • 55,808 POSTS
This happens when the throttle body needs to be serviced which is common, here is a video to show you how.
https://youtu.be/Ui8zhMLp5EM?si=-BObVeG3k4BEAeGG
Also, lets go over this guide which can help as well
https://www.2carpros.com/articles/stall-at-idle
Please go over these guides and get back to us.
Jun 25, 2024 at 8:21 AM
