2000 Dodge Caravan Caravan won't start
99,800 MILES • 6 CYL • FWD • AUTOMATIC
SKAYSER2
For the last several months all the lights on the van including the interior and dash lights "flicker" slightly. Not all the time though. It seemed to get worse when the cooling fan was running. I have cleaned the battery terminals and checked charging voltage. Seems okay at 14.5 volts or so. Today when I checked it again it tested at 12.4 volts. Not enough, I know. I didn't have time to check further and the wife had to get to work. Has luck would have it, it was towed home this evening. It would turn over most of the time and every once in awhile nothing at all. After testing and checking more, I found the two battery cable to power center terminal stud nuts 3-4 turns loose. This would probably explain the "flickering" and the not turning over at all. Do you agree? After tightening the terminal nuts it did start but only stayed running long enough to drain the fuel pressure. I have checked and swapped out the FP relay and checked the ground and power to the pump. All seems fine but the pump won't run. I'm guessing it's bad. My question is: Would running the system with a loose connection as I found at the power center cause the pump to fail or is it just a coincidence?
Jun 16, 2008 at 3:48 PM
  • 75,988 POSTS
Check the fuel pressure with a gauge and comeback with the readings we go from here-
Oct 23, 2019 at 7:47 AM
SKAYSER2
No fuel pressure at all- pump dosen't run- power at the pump comes on for a few seconds- relay checks fine w/ohm meter. The ground continuity at the pump loom connector is good also. Thanks for your time.
  • 75,988 POSTS
power at the pump comes on for a few seconds-The pump should come on for a few secs before the relay de-energizes-replace the fuel pump
