HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Exhaust
White Smoke
2000 Dodge Caravan
BMAN23
MEMBER
2000 DODGE CARAVAN
6 CYL
2WD
AUTOMATIC
156,432 MILES
My van puts out a big cloud of white smoke when I start it, but it doesn't do it continually.
Tuesday, October 28th, 2008 AT 4:09 PM
BMRFIXIT
MECHANIC
Is it overheating ?
check coolant level if its low suspect headgasket issue
check oil too
white smoke is a sign of burning antifreeze
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, October 28th, 2008 AT 7:23 PM
Please
login
or
register
to post a reply.
Related White Smoke Content
1991 Dodge Caravan White Smoke
After Engine Gets Warm (after Freeway Driving), Then I Park. When The Car Is Started Again, After Parking For A Few Minutes, Volumes Of...
Asked by
freq333
1 ANSWER
1991
DODGE CARAVAN
GUIDE
White Smoke
There are different levels of white smoke/steam which could be a normal occurrence. A small amount of water is produced as a normal bi product of the combustion process and...
1994 Dodge Caravan While Idling White Smokes Bad When...
While Idling My Car Smokes White Smoke Bad When I Start Going On Down The Road Theres No Smoke And The Car Has Plenty Of Power And Starts...
Asked by
trsbrg1
1 ANSWER
1994
DODGE CARAVAN
White Smoke Raw Fuel Out Exhaust Dodge Grand Caravan...
Van Was Running Rough So I Changed The Spark Plugs And Wires, Starting Running Worse And Code P 0206 And P0206 And P0355, P 0356...
Asked by
triciashade
1 IMAGE
2002
DODGE CARAVAN
White Smoke Out Of Exhaust Pipe
I Just Bought A 1998 Dodge Caravan With 67,000 Miles On It. I Noticed That It Has White Smoke Coming Out Of It When It Idles. Once On The...
Asked by
luvkylebriechrle
1 ANSWER
DODGE CARAVAN
1994 Dodge Caravan White Smoke Coming From Heating...
I Have A 1994 Dodge Caravan With About 225000 Miles, Which I Would Like To Hang Onto For A Little While Longer. The Problem Is That While...
Asked by
mmartinpy
1 ANSWER
1994
DODGE CARAVAN
VIEW MORE
Exhaust System Removal
Catalytic Converter Replacement
Oxygen Sensor Replacement Dodge
