If youre key pops out when youre while the van is running, Youre in need of a new ignition key cyl, Also for youre Van not starting at times just hearing click sound, Could be the ignition switch, Also starter could be weak, Also could have a weak coil pack system. For the creeking noises from the front end you are explaining, Could be youre front chasis needs to be greased, Ball joints / Tie rod ends,
Good Luck.
SPONSORED LINKS
Wednesday, June 6th, 2007 AT 3:55 AM
