1999 Dodge Caravan vibrating
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SPEED3961
  • 11 POSTS
[img:2bcfb04d1b]http://www.2carpros.com/forum/automotive_pictures/387517_Im000117a_1.jpg[/img:2bcfb04d1b]
car vibrates bad and smells like something is burning and smokes from the front end. then it goes away for a few days and the come back. no idea
Jul 25, 2009 at 4:07 AM
BUDDYCRAIGG
  • 2,262 POSTS
first thing to do is the next time it start smoking, you open the hood and visually inspect for the cause.
smoke is a bad thing, you could be driving a fireball waiting to happen.
Jul 25, 2009 at 4:59 PM
SPEED3961
  • 11 POSTS
[quote:ed7daaa3ec="buddycraigg"]first thing to do is the next time it start smoking, you open the hood and visually inspect for the cause.
smoke is a bad thing, you could be driving a fireball waiting to happen.[/quote:ed7daaa3ec]
i did that cant find anything
Jul 26, 2009 at 1:42 AM
BUDDYCRAIGG
  • 2,262 POSTS
what does the smoke smell like?
Jul 26, 2009 at 10:42 AM
SPEED3961
  • 11 POSTS
it almost smells like brakes. but what is strange it only happends when the car gets hot. then when the car gets cool its stops. if the caliper was no good would this happen.
Jul 26, 2009 at 11:18 AM
BUDDYCRAIGG
  • 2,262 POSTS
next time you smell it, get out and put your hand on the both front wheels close to the center, they will be slightly uncomfortable to touch, but you should be able to stand it.
if it's too hot to be able to keep your hand there for 10 seconds, then your brake is most likely dragging.
If you have plastic hubcaps, you will have to remove them.
Jul 26, 2009 at 11:29 AM
SPEED3961
  • 11 POSTS
i burned my hand. i just changed the master cylinder about a month ago would that have anything to do with it. they both were buring hot could they both go at the same time.
Jul 27, 2009 at 3:30 AM
BUDDYCRAIGG
  • 2,262 POSTS
[quote:1b1f889bea="speed3961"] i just changed the master cylinder about a month ago would that have anything to do with it.[/quote:1b1f889bea]
Since you did change it, it is possible, but not very likely.
The 3 more common problems that keep the calipers from releasing are.
the hoses are bad on the inside and acting like a check valve keeping hydraulic pressure in the caliper.
the piston seal in the caliper is worn out and not helping to pull the piston back into the caliper.
the caliper can not slide freely.
Jul 27, 2009 at 3:56 AM
SPEED3961
  • 11 POSTS
i checked the calipers and my wife put her foot on the brake and i can see the piston retract. its when the car gets hot u can feel the car being pulled. the brakes are frezing after it gets hot.
Jul 27, 2009 at 4:41 AM
BUDDYCRAIGG
  • 2,262 POSTS
I've never heard of such, that's a new one on me.
Jul 27, 2009 at 5:08 AM
BUDDYCRAIGG
  • 2,262 POSTS
ok, i have a shot in the dark idea.
if you have the master cylinder too full of fluid,
and when the engine gets hot, it is causing thermal expansion of the brake fluid, then the fluid doesn't have any place to go, and creates pressure in the calipers.
that's all i can think of.
Jul 27, 2009 at 5:27 AM
SPEED3961
  • 11 POSTS
how about the master cylinder. because when the car is running the master is under presure. maybe the valve is no good and not letting the fluid back into the master.
Jul 27, 2009 at 6:03 AM
BUDDYCRAIGG
  • 2,262 POSTS
I've never seen a master cylinder fail in such a way.
Jul 27, 2009 at 7:02 AM
SPEED3961
  • 11 POSTS
when the car is off the piston goes back in and when the car is on the piston doesnt go back in.
Jul 27, 2009 at 7:19 AM
BUDDYCRAIGG
  • 2,262 POSTS
Try one thing for me and i'll maybe buy into the idea.
While the calipers are released, start the engine, but do not touch the brake pedal.
Check the calipers to see if they tightened up on the rotors
Jul 27, 2009 at 8:05 AM
SPEED3961
  • 11 POSTS
ok i jacked up the front end with the car off both wheels spin put on the brakes both wheels are locked. took foot off brake and both wheels spin put foot on brake took foot off brake driver side wheel spins pasanger side is locked.
Jul 28, 2009 at 1:25 AM
SPEED3961
  • 11 POSTS
forgot to tell u when i started the car in last reply sorry.
ok i jacked up the front end with the car off both wheels spin put on the brakes both wheels are locked. took foot off brake and both wheels spin. start car put foot on brake took foot off brake driver side wheel spins pasanger side is locked.
Jul 28, 2009 at 1:27 AM
BUDDYCRAIGG
  • 2,262 POSTS
well i didn't want you to step on the brakes when you started the engine.
from what you just said, i'm saying it's a problem with the hose or caliper on the right side.
I give it 80% chance of being the hose.
Jul 28, 2009 at 2:34 AM
SPEED3961
  • 11 POSTS
i just noticed that the rubber seal inside the cap for the master cylinder doubled in size its the second time in a month this happened and i was told the fluid is contaminated how does this happen and can it be true. that would be the reason the why my hose is no good.
Jul 28, 2009 at 7:12 AM
ABOUT2POP
[quote:5d0a60bbe8="speed3961"]i just noticed that the rubber seal inside the cap for the master cylinder doubled in size its the second time in a month this happened and i was told the fluid is contaminated how does this happen and can it be true. that would be the reason the why my hose is no good.[/quote:5d0a60bbe8]
I had to change mine out a few month ago because tran. fluid was put in there instead of brake fluid. The brake fluid causes all the seals and anything rubber like the hoses to swell. I was told I would have to have everything in my brake system replaced. If you have ABS that's going to cost a lot of money to get fixed.
I couldn't afford that kind of fix. This is what I did. I replaced the master c. and added new fluid. As I went around to bleed the brakes I looked at the fluid coming out. If it was red I figured I would have to replace that sides brake related parts. My brakes work GREAT now with only replacing the master c.
My fluid was contaminated for 4 months and only (to my knowledge, which isn't much) caused damage to the master c. No matter what you're going to have to replace it and from what you're saying the hoses as well. Maybe the entire braking system.
Sorry for the story, I'm a pregnant woman :)
Jul 28, 2009 at 10:35 AM
BUDDYCRAIGG
  • 2,262 POSTS
[quote:a7fbc280b3="speed3961"]i just noticed that the rubber seal inside the cap for the master cylinder doubled in size its the second time in a month this happened and i was told the fluid is contaminated how does this happen and can it be true. that would be the reason the why my hose is no good.[/quote:a7fbc280b3]
EEK!!!!
Now we see what's going on.
as a mechanic, for safety reasons, i have to tell you that every rubber part in the system needs to be replaced. and the system completely flushed with new fluid.
I've delt with this problem a few times.
I had to replace the maser cylinder,
the font hoses,
I normally try to rebuild the calipers myself with a new seal kits if they are a lot less that a rebuild caliper from the store (and i never trust rebuilt parts anyway)
the rear hose, (or hoses)
and slave cylinders or calipers.
so far, i have not had to replace the ABS unit, but it is a possibility that it could fail at a later date.
What you do will be your own decision. but i will tell you a bedtime story.
customer comes in.
accidentally put power steering fluid in. and the master cylinder had failed,
I tell them that they need to replace everything, But since I'm just a dumb mechanic and don't know anything, he insists that we only do the master cylinder.
We refuse and he takes his car, saying that he'll do it himself.
about 2 months later it comes back on a flatbed.
one of the rear wheels was locked up and had a flat spot on the tire.
(a flat spot is where the tread is worn away, and the tire is no longer round)
I noticed the car, and requested that the writer assign it to me.
we pull it in with a floor jack under the locked up wheel and i start checking things out.
the master cylinder was new
the front hoses were new
the front calipers were new
and now the right rear caliper was locked up.
I'm betting that he was replacing one piece at a time as each one slowly failed.
so i got to replaced everything this time,
and he had to buy a new tire as well.
the service writer "played dumb" when the guy came to pick it up and asked what happened.
the guy said the wheel just locked up while he was on the outer road, (that's a 45mph zone).
it could have happened on the highway...
you are driving a minivan, so i'm going to assume you have kids.
do what you think is best.
Jul 28, 2009 at 12:27 PM
SPEED3961
  • 11 POSTS
this is crazy foot on and off the brake while car running and when the car warms up the passanger side wheel locks up.
Jul 29, 2009 at 12:54 AM
BUXNBAAS
I actually have heard of this once, It turned out to be contaminated brake fluid, lots of water in it. Calipers get hot, boil water out of fluid and bingo, calipers wont release properly until they cool. But In all my years of dealing with cars, I've only heard it once. could try flushing brake system with denatured alcohol (correct me on this if thats not good procedure). The alcohol would pull the water out.
Jul 31, 2009 at 6:58 PM
CARADIODOC
  • 34,415 POSTS
Water won't cause this issue. It will lower the fluid boiling point. The resultant vapor causes a low mushy brake pedal. It will also promote corrosion in the metal lines.
I was thinking fluid contamination or rust in the hose brackets that constricts the hoses, but the comment about the rubber seals in the master cylinder caps growing is proof of fluid contamination. The number of comments about replacing EVERYTHING in the hydraulic system with rubber parts is exactly correct. Anything with rubber seals must be replaced at the same time and all the metal parts and lines must be flushed with brake parts cleaner and dried. The type of rubber used in brake systems is not compatible with petroleum products. Any part not replaced will allow contamination to leech out into the new fluid and the entire system will be contaminated again.
Antilock brake hydraulic controllers are full of rubber seals too.
caradiodoc
Aug 7, 2009 at 2:45 PM
