Stalls when driving then starts right up?
BGROVES
JOE,
THANKS SO MUCH FOR YOUR TIME. HERE ARE THE ANSWER TO YOUR QUESTONS.
1 NO CODE WAS SHOWING?
2 DON'T KNOW WHAT CODE WAS SHOWING FOR THEM TO CHANGE THE FUEL PUMP, THEY SAID ON THERE MACHINE THAT THE FUEL PUMP SHOULD BE CHANGED!I DON'T KNOW IF THE FILTER WAS CHANGED?
3 MY ENGINE IS 3.3
BOB
Monday, September 21st, 2020 AT 12:15 PM (Merged)
CH112063
  • 1,320 POSTS
You are feeling the problems that occur when a van like yours does this, if you need any advice about anything just let me know. You cannot replace a fuel pump, and expect to have good fuel pressure. Maybe sometimes, but not a 'Dodge'. Its plastic comes apart and gets swtuck in the filter, this can cause the new pump to fail.
LARRYNEFF
  • 1999 DODGE CARAVAN
Have a 1999 dodge caravan it just dies and you can start it back up in a few sometime it wont for days sometime it every day
Monday, September 21st, 2020 AT 12:16 PM (Merged)
LARRYNEFF
Sometime it wont die for days sometime it every day
HMAC300
  • 48,601 POSTS
Check fuel pressure and clean throttle plate on both sides with choke cleaner they gum up and cause stalling
