1999 Dodge Caravan Dashboard Dead
150,000 MILES • 4 CYL • FWD • AUTOMATIC
RBARRETO
All gages and lights in the dashboard have gone dead. Checked fuses relays and wiring, didn't find anything wrong. I figure that it has to do with the dash board having a single power source or maybe a common signal processor that has gone bad. Help.
Jan 20, 2008 at 2:27 PM
LEGITIMATE007
  • 5,121 POSTS
if youve confirmed that all of those areas are fine, then your next step would be either to check the dimmer switch to make sure its ok and have your bcm or body control module checked. that happened to me one time and i did everything i could with no success until i found the bcm and took a look at it and found that one of the wire terminals had burned out. so i scraped the terminal and got all of the burnt crap off of it and everything was good as new.\check it out and let me know what happens.
Jan 29, 2008 at 3:49 AM
