1999 Dodge Caravan Dash lights come on while turning
UMRJAKE57
  • 1999 DODGE CARAVAN
  • 4 CYL
  • 162,000 MILES
About 2 months ago the van was idling low, and the brake and oil dash lights would come on while making hard turns. I cleaned the Idle Air Control Valve and all of the problems went away. Now, the van idles fine, but the dash lights still come on while turning.
Sunday, October 4th, 2009 AT 10:21 AM
CH112063
  • 1,320 POSTS
Which lamps come on? Exactly which lamps?
Your oil pressure is low possibly, and your losing pressure at low speeds and when you lose pressure on turns so check the oil too. Lot of miles. You need help? Check back Later. If you need help.
My name is Joe. Ok umrJake57. If the oil is too thin, also bad.
Sunday, October 4th, 2009 AT 2:09 PM
