HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Not Running
1999 Dodge Caravan
CASTRO5858
MEMBER
1999 DODGE CARAVAN
4 CYL
2WD
AUTOMATIC
180,000 MILES
Car does not start got wet
Wednesday, January 27th, 2010 AT 9:28 AM
TOOOMANYTOYS
MECHANIC
When you say the vehicle got wet do you mean flooded? If so it maybe hydro locked. If its more like when it rains I would inspect the crank sensor and coil pack. Use a water spray bottle and squirt around suspected area to see if it stalls
SPONSORED LINKS
Wednesday, January 27th, 2010 AT 9:37 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Caravan 99 No Start No Voltage To Coil
Hi My Caravan 99 2.4 Wont Start I Have Chage The Cam And Crank Sensor The Fuel Pump Its Working, But I Have No Spark Ive Change The Pcm For...
Asked by
Dodgerage
2 IMAGES
1999
DODGE CARAVAN
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1999 Dodge Caravan 3.3 Engine Does Not Start
1999 Dodge Caravan With 3.3 Engine With 95,000 Miles Does Not Start. I Had The Battery, Starter And Alternator Tested And They Checked Out...
Asked by
Chris Velazquez
1999
DODGE CARAVAN
New Serpentine Belt Now Can Will Not Start
Okay, First Started Having Problems When My Cousin Was Driving He Drove Through A Big Puddle And The Serpentine Belt Fell Off Then We Put...
Asked by
Steve Paffrath
1999
DODGE CARAVAN
1999 Dodge Caravan Will Not Start
I Am Having Trouble Getting It To Start. It Has A Full Tank Of Gas. It Ran Fine Last Night. Went Out To Start It Go To Work And It Just...
Asked by
eaglesawaypam
1 ANSWER
1999
DODGE CARAVAN
Cars Runs 24 Hrs Most Days, And They Run Hot And This Problem Has Popped Up On Now Three Different Cars, Its Starts With The Alt Or Batt...
Asked by
milestonetaxi
1 ANSWER
1999
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
