HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Drivetrain
Transfer Case
SPONSORED LINKS
1999 Dodge Caravan
LATINKING
MEMBER
1999 DODGE CARAVAN
Engine Mechanical problem
1999 Dodge Caravan 4 cyl Two Wheel Drive Automatic
My timing velt is caming out, I check everythin and look ok. But velt is coming out, tensor look ok!
Thursday, February 12th, 2009 AT 5:54 AM
BMRFIXIT
MECHANIC
Crank gear should hold it in place and if its loose and jumping
then I would replace the belt and tensioner
check water pump
SPONSORED LINKS
Thursday, February 12th, 2009 AT 3:40 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1989 Dodge Caravan Gas Problems
Engine Mechanical Problem 1989 Dodge Caravan 4 Cyl Two Wheel Drive Automatic The First Problem Is That My Car Will Only Run 1 Time In...
Asked by
jennelled
1989
DODGE CARAVAN
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
2005 Dodge Caravan
Heater Problem 2005 Dodge Caravan 4 Cyl Two Wheel Drive Cold Air From Two Left Vents Hot On On Right
Asked by
runforestrun
1 ANSWER
2005
DODGE CARAVAN
1996 Dodge Caravan Put Back
Transmission Problem 1996 Dodge Caravan V8 Four Wheel Drive Automatic I Had Friends Help Me With A Problem They Took Out Some Kind Of...
Asked by
al
1 ANSWER
1996
DODGE CARAVAN
1999 Dodge Caravan Cv Joint
How Do You Do A Engine Alignment After Installing A Cv Joint Shaft? What Do I Need Exactly To Do This? It Is A 3.3 Engine. Thanks
Asked by
tina34
1999
DODGE CARAVAN
Can Air Conditioning Affect Transmission?
Lately When I'm On The Freeway And My Ac Is On, My Automatic Transmission Stops Shifting. It Gets Stuck, So I Can Only Go About 60 On...
Asked by
lightfeet
1999
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Service Ford Super Duty F-250
How to Service the Transmission
Online car repair manuals
