1998 Dodge Grand Caravan No Horn No Cruise
JODYROSS
98 grand caravan-horn and cruse went bad at the same time, checked all known fuses and relays,
any suggestions b-4 parts changing episode
Mar 28, 2006 at 10:15 AM
RAYHUT
  • 134 POSTS
have you checked your fuses under the hood.
Mar 29, 2006 at 9:50 PM
VANDRAGON
  • 298 POSTS
i say clockspring, there is a recall about it? if you haven't had it replaced and you bought the van new, call the dealership and it will be replaced for free. i am surprised that the airbag light isn't on.
Mar 30, 2006 at 6:06 AM
Suggested Repair
Check the fuses under the hood. If those are good, the clockspring is the likely cause of the horn and cruise failing together; if the van was bought new and the clockspring was never replaced, contact the dealer about a possible free recall replacement.
Conversation Summary
The owner of a 1998 Dodge Grand Caravan says the horn and cruise control failed at the same time after known fuses and relays were checked. One expert asks whether the under-hood fuses were checked. Another suggests the clockspring, notes a possible recall that may cover free replacement for an original owner, and is surprised the airbag light is not on.
