1998 Dodge Caravan windshield squirters don't work
74,851 MILES • 6 CYL • FWD • AUTOMATIC
BROKEN-GARGOYLE
My windshield squirters quit working a while ago,
wipers work fine .
What can I do to fix this ? or to track down the problem
Thanks in advance for your help
Jim
Jul 21, 2008 at 4:49 AM
KLSHIEL
  • 163 POSTS
Do you hear the motor whining when you hit the washer fliud. If the motors aren't working check the fuses, wiring, and connections. If all of that is fine you need new motors. If the motors are whining either the motors are brokin, stuck, or burned up inside or you have clogged lines. To unclog the lines you can try running hot water over them, or blowing air pressure through them. You can verify that the motors work or not by placing different lines on it and checking if fluid flows. Replace the lines and squirt tips before the motors if the motors are working as this is cheaper.
Jul 21, 2008 at 5:12 AM
