Radiator fan relay location
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOCLEVINGSTON
I have determined that the radiator fans are inoperative due to failure of the radiator fans relay. I cannot locate the radiator fans relay under the hood. The radiator fans 40A fuse is located in the fuse/relay box above and to the right of the battery. Where is the radiator fans relay located?
Jun 10, 2010 at 5:14 AM
DOCFIXIT
  • 18,828 POSTS
There is not a relay this system uses a controller which is up by the fans on the drivers side. Here is the location in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 10, 2010 at 5:29 AM
KPOIRIER1125
It worked perfect! I got the part and it took me about twenty minutes to install. All fixed!
Jul 15, 2018 at 7:10 AM
MAMCC
Where can I find the radiator fan relay my van with a 2.4 liter engine?
Jul 15, 2018 at 7:11 AM (Merged)
MAKAHA1
Six cylinder two wheel drive automatic.
Cannot find relay. I have a 1999 and a 2000 Caravan. Cooling fans on 1999 do not turn on. I think it is the relay. Fans work.(bench test) Looked on left side of frame in the front. Removed air filter housing, no relay. Understand it should be a two inch square. Followed wire, goes into large wire harness under the fuse and relay distribution box. Can you help? Tried a lot of people and got many answers, none good.
WILLIE9622
After never having any cooling problems with this van for almost ten years, I had to replace the radiator fan relay last week because the fans were only working intermittently, and were staying on after I turned the engine off. After installing the new relay, I am now having the same problems with the fans. Is it possible that I got a bad relay? Or is there another part that I should check that can be causing this? I have tried to retrieve a trouble code, and get two, pause, 55. I cannot find that code anywhere.
BLUELIGHTNIN6
  • 16,542 POSTS
This would be due to a faulty fan motor. Replace the fan motor and clear any trouble codes stored. Using a diagnostic scanner is much easier in retrieving codes and most auto part stores will do this for you free of charge.
  • 110,248 POSTS
Power distribution box under hood.
LARRYGRANT
Engine cooling problem, six cylinder.
Trying to find where the cooling fan relay is located?
Jul 15, 2018 at 7:12 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Radiator coolant fan relay is located on front bumper reinforcement behind the grille.
JOSHINGME
Where is the cooling fan relay on my Grand Caravan with a 3.3 liter engine?
INDYUKE
  • 416 POSTS
They are right. The codes indicate that your engine is running lean. The K&N air filter system might be contributing to that. That type of system tends to flow more volume than the stock system, and if the factory MAF sensor metering orifice is replaced with just a straight pipe then it will read lean.
  • 75,988 POSTS
Can you please let me know what year it is?
LILANGEL922US
I have the part. The person I have to work on my car could not find it anywhere. AutoZone was no help either. They said they had no clue. Everywhere I have looked says different places.
All I want to know is Where is the radiator fan relay?
MBKAYE4038
On my 1997 the relay is near the strut mount on the driver side. Remove the air filter boxes and it is under them to the side. I hope this helps. It took me awhile to find it when mine failed.
DAN DZIENDZIELEWSKI
Four cylinder two wheel drive automatic.
Cooling fan keeps running after vehicle turned off. Needs new relay plug but unable to find location on frame for ground so it can be replaced. Where is it? Thanks for the help.
  • 75,988 POSTS
The radiator fan relay its at front left frame rail. See below.
https://images.2carpros.com/forum/automotive_pictures/12900_fan_relay_3.jpg
JOVANYSANLEON
Where is the cooling fan relay switch located at?
LEGITIMATE007
  • 5,121 POSTS
There is a box of relays in the engine compartment with a cover on it, it should be right inside there and on the back side of the cover is a diagram which describes which relay belongs to which component.
ALLENANDRUBY
Does this model Dodge Grand Caravan have radiator fan relay(s) or just a radiator fan fuse? And if so, where is it located? The Haynes manual doesn't seem to give me a clue.
Nov 26, 2018 at 3:24 AM (Merged)
there is an electronic relay on the left front frame rail. it is a common failure.
SAMSFUNSHINE
hello i have a 97 caravan and i cannot find the switch or relay on the engine for the fan
CARADIODOC
  • 34,413 POSTS
It's an unnecessarily complicated module on the core support, next to the left side of the radiator, half way down. It must be bolted on to dissipate heat. It will get hot enough to burn your hand, and it will self destruct if allowed to overheat.
This module is used to vary the fan speed for various conditions. It is slowed down to prevent complaints of excessive fan noise. A lot of expense and unreliability to quiet a little noise.
caradiodoc
JEFF DAI
Engine Cooling problem
1998 Dodge Caravan 6 cyl Two Wheel Drive Automatic
I need the location of the radiator fan relay on the van.
LEGITIMATE007
  • 5,121 POSTS
here is the photo of the relay
https://images.2carpros.com/forum/automotive_pictures/88091_relay_cara_1.jpg
VJHILL
Where is the cooling (radiator) fan relay on a 1998 Dodge Grand Caravan?
  • 75,988 POSTS
Cooling Fan Relay Location Radiator Fan Relay Mounted On Left Front Frame Rail
https://images.2carpros.com/forum/automotive_pictures/12900_r_5.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_r1_3.gif
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
KENTONAMICK
Could you please tell me where the radiator cooling fan relay is located?
  • 75,988 POSTS
Check fuse no.4 40amp also see below for relay location
https://images.2carpros.com/forum/automotive_pictures/12900_fan_relay_6.jpg
FIXITMR
  • 9,989 POSTS
yah i got same problem suddenly 2000! i LIKE that last CLOSEUP PIC!! but my question is can it be BYPASSED or where do you buy it!?
Jul 13, 2019 at 1:24 PM
FIXITMR
  • 9,989 POSTS
OUCH my 2000 grandvan sport relay NOT where indicated!!
Jul 13, 2019 at 11:36 PM
JACKPAT
where is the cooling fan relay located
Jul 14, 2019 at 5:17 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2006_dodge_caravan_cooling_fan_relay_part2_1.jpg
There you go.
JACKPAT
I cannot read the drawing you . Please send a clearer drawing.
SATURNTECH9
  • 30,869 POSTS
Sorry about that some of the image's are hard to post clear i emailed you the diagram hopefully you can read that one.
DEJANMILOJEVIK
please tall me the exact location of the radiator fan relay.thank you
  • 75,988 POSTS
Its at top left front frame rail
https://images.2carpros.com/forum/automotive_pictures/12900_fan_relay_8.jpg
CHRISXX
Gentlemen,
Thanks in advance for your assistance! I'm replacing a radiator fan relay on a 2000 4cyl Dodge Caravan and can't get the relay unplugged from the harness. I'm afraid of damaging the connector which of course I'll need to connect the new relay.
Can you point me to an illustration or advise me on how to unplug the relay from the wiring harness? Also, once installed, if it functions properly, do I need to use the pigtail that comes with the new relay? I'd like to avoid the pigtail splicing if possible.
Thanks sincerely!
chrisxx
  • 110,248 POSTS
chances are it is hard to disconnect because it heated up and melted. It should pull out of the socket. As far as the pigtail, if they gave you one, there is a reason or update. If I'm correct and the original one melted down, you will want to replace it.
WRENCHTECH
  • 20,760 POSTS
They gave you that new pigtail for a reason. They have a problem with the plugs melting on to the relay. Cut the wires and splice in the new pigtail.
Jul 14, 2019 at 5:18 AM (Merged)
CHRISXX
Jacobandnicolas/Wrenchtech,
Thank you guys most sincerely for your prompt & informative response! Guess that eliminates any need to know how to unplug the relay from the harness.
Thanks again!
Chrisxx
