The brake pedal went to the floor....would not pump up. No fluid was leaking anywhere. Decided to replace the master cyl. Did that , bled the brakes and all worked well. Thought the problem was solved. Two days later No pedal! Bled the brakes again and got air from rr. Figured just didn't get all the air the first time. Drove it a couple of days and it did it again! Maybe a defective master cyl. Replaced with a secound new one. Good brakes again. Two days later ...Air ..in the RR again! No fluid leaks anywhere but still getting air in the right rear! Had another shop bleed the system and two days later ..air again in the RR! Still no leaks. Where is the air coming from?
Feb 26, 2010 at 2:30 AM
