ABS light?
125,000 MILES • V8 • FWD • AUTOMATIC
CWR_PWR
Service Engine and ABS light comes on periodically (not necessarily both at the same time) and when it does the gauges go out. I have had it in the shop several times and have replaced control modual, battery and a few other things. The other problem is the left turn signal even after changing all the bulbs still blinks very fast. HELP
Aug 22, 2010 at 1:35 PM
  • 110,244 POSTS
When the signal flashes fast, are both front and rear lights working? Usually a fast flash indicated a burned out bulb.
This video will show you how to read the codes.
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/rTtAnsOlZU4
Mar 1, 2021 at 4:57 AM
CWR_PWR
all of the bulbs work and from time to time it blinks normally. Bulbs are not burned out they are all brand new. They told me they scanned but I have no idea what the results of what the scan was.
  • 110,244 POSTS
Have you tried replacing the flasher? Also, can you find out what code they got?
