1998 Dodge Caravan 2 cylinders not receiving power through
MARTELL49
  • 1998 DODGE CARAVAN
  • 6 CYL
  • 150,000 MILES
My van shakes a lot when driven and does not accelerate well. I checked to see if power was being sent from coil to spark plugs and found out two are not receiving power. Initially I thought it was the coil so I replaced it. To my surprise it has not fixed the problem. 2 cables are still not sending power. Does anyone know if there is a sensor that is responsible for this problem. I know sensors on this vehicle are problematic because they seem to be going out. Can anyone please help.
Thursday, December 18th, 2008 AT 1:35 AM
BMRFIXIT
  • 19,053 POSTS
Check ignition coil pack wiring
you have one supply of power from the ASD relay
and 3 ground that the PCM responsible to ground
if it is a sensor and or relay all will be effected
need to check wires between coil and PCM
checking for an open wire
and if all OK PCM no good
Thursday, December 18th, 2008 AT 6:08 AM
