1998 Dodge Caravan
THOMAS43
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 224,000 MILES
Rear door electric lock sounds like it is working, but the door will not unlock - do you have a picture of this door lock in position - I can not see into the door area where the rods run from the actuator to the lock itself. Something seems to be disconnected or broken!
Wednesday, November 3rd, 2010 AT 8:22 PM
  • 109,885 POSTS
I don't have a picture. Have you checked to make sure the actuator is getting 12 volts?
Monday, November 8th, 2010 AT 7:55 AM
THOMAS43
Everything working except the arm attached to the lock will not lift the lock as before to unlock the door.
Monday, November 8th, 2010 AT 10:52 AM
  • 109,885 POSTS
Either the actuator is bad or it isn't getting enough power. Here is a "How To" test for checking it.
Let me know what you find.
https://www.2carpros.com/how_to/door_lock.htm
Monday, November 8th, 2010 AT 11:12 AM
