1997 Dodge Caravan How to acess the rear rocker arm cover
1997 DODGE CARAVAN
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKIPBCS
I have observed oil spots under the car which look like they're coming from the rear rocker arm cover. I have had oil leaking from the front cover in the past but simply tightened the bolts and the leaking stopped. How do I access the rear cover in order to tighted the bolts or change the gasket if necessary?
Sep 7, 2010 at 12:10 PM
  • 110,244 POSTS
What size V6 is it?
Sep 7, 2010 at 2:56 PM
SKIPBCS
It's a 3.3L V6.
Sep 8, 2010 at 2:13 PM
  • 110,244 POSTS
Once you remove the intake, you will be able to gain access to the valve cover. It's tight, but can be done.
Sep 9, 2010 at 2:46 AM
SKIPBCS
That's kind of what I was expecting but hopeful that you'd pull one of your rabbits out of a hat.
Much appreciated. Thanks.
Sep 9, 2010 at 11:49 AM
  • 110,244 POSTS
I wish I had better info for you. I don't think anything is easy anymore.
Let me know if you run into trouble or have other questions. Also, make sure not to overtighten the new gaskets. If they leak after you put it back together, you'll end up with less hair than me.
Sep 10, 2010 at 6:14 AM
