1997 Dodge Caravan Shakes Over 60 MPH
PRECIOUSTRIO
I have a 1997 Dodge Caravan. The car has actually been very good until recently. When I drive the car passed 60 mph the car starts to shake and it kind of fells like I have no control of the vehicle. When I'm driving under that speed the car runs fine. I just had a tune up and a master cylinder put in. I took it to my family mechanic and he told me my fluid was fine and clean. He said it might be my torque converter. Do you have any advice on what it might be? Oh one more thing I had a new fuel pump but in also about 5 months ago.
Feb 23, 2007 at 8:09 AM
CHEVY22
  • 1,375 POSTS
this isthe kind of problem that needs to be isolated , so there may be many questions asked ,
how long has it been since the tires were balanced
how long since anyone has looked at the tires for a broken belt,
lets start there these are pretty obvious things that may cause a generic vibration 60+mph
let us know
Feb 23, 2007 at 10:22 AM
PRECIOUSTRIO
It's only been happening for about 3 weeks. It's been awhile since i got my tires balanced. No nobody has checked the belts that i know of. But my mechanic has been working on my brakes on and off for 1 week. I feel it is so strange that it doesn't happen all the time either.
Feb 23, 2007 at 10:32 AM
CHEVY22
  • 1,375 POSTS
it may be something else , and yes it is strange i always aks the normal questions to make sure it isnt maint related , the converter makes sense but someone really needs to check the car out the right way and give you a real answer , maybe consider taking it to a good trans shop , most wont even charge you to check it out ,
let me know what happens if you can
Feb 23, 2007 at 10:45 AM
Suggested Repair
Check tire balance and inspect the tires for a broken belt, which can cause vibration above 60 mph. If those are fine, have a transmission shop inspect the vehicle, including the torque converter.
Conversation Summary
The owner of a 1997 Dodge Caravan reports shaking and a loss-of-control feeling above 60 mph, while the vehicle runs fine at lower speeds. Recent work included a tune-up, a master cylinder, and a fuel pump about five months earlier. A mechanic found the fluid clean and suggested the torque converter. The expert recommends first checking tire balance and looking for a broken tire belt, then taking the vehicle to a transmission shop for a proper inspection if those checks do not explain the vibration.
