1997 Dodge Caravan BELT TENSIONER
PUCK288
  • 1997 DODGE CARAVAN
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
HOW DO I REMOVER THE BELT TENSIONER I HAVE THE BOLTS OUT I THINK THERE ARE 3 ONE THROUGH THE ALT. ONE DOWN THE BOTTOM AND ONE IN THE BACK IS THERE ANOTHER OR A DIAGRAM FOR THIS THAT I CAN SEE
Monday, September 14th, 2009 AT 11:28 AM
CARADIODOC
  • 33,916 POSTS
Are you referring to the spring-loaded pulley? It only has one 15 mm nut to remove from the backside of the mounting bracket. It sounds like you're trying to remove the entire bracket. The alternator and its bolts have nothing to do with the tensioner.
Caradiodoc
Tuesday, September 15th, 2009 AT 12:45 AM
