1997 Dodge Caravan all dash lights and guages stopped worki
SACKVILLE504
Electrical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
while driving i lost all of my gauges and dash lights all fuses appear to be intact. i am a single mother of 6 and i apologize for not being able to donate for you helping me
Sep 19, 2010 at 1:15 AM
  • 110,244 POSTS
Not a problem. We're happy to help. First, check the most basic thing. Make sure the wiring harness to the rear of the cluster is tight. If that isn't the problem, have the body control module tested and check body grounds. If all of that checks out good and there is power to the cluster, the cluster may be the problem.
Sep 20, 2010 at 8:06 AM
SCOYBOY
  • 10 POSTS
there is a clockspring recall BUT there will be more comin with that whole multi function, brake switch, cruise,BUT the dash pins could be bad but most likely a sensor that has been set up to fail and send improper volts that will not engage relay to ? unit/if 1 of four groups of problems exist ie. abs, cruise, gauges or ck eng, gauges die and lights ON when turn off key, etc. The point is...we cant point at an item to say RECALL ...CUZ the next lack or surge or bent wire or low batt will trigger A DIFF prob.. So THEY started the "RE-Program YOUR COMP/Body Module CAMPAIGN!!!!Nice little $400 REPAIR TICKET-its a sensor set up like a "Comp. Virus" BECAUSE ....EVERY SINGLE UNIT WORKS UNDER DIRECT POWER EVEN IF FAULT CODE READS. sO UNTIL ENOUGH TSB'S (dEALER) TURN INTO RECALLS BY THEN THEY MAKE 3 TIMES THE MONEY AND HASSLE THAN TO MAKE BETTER PARTS, SIMPLER, ETC. I've had everry caravan prob before and its not because they are crappy (or I wouldnt have had them for 15 years-BUT only 3.3 and 3.8) its because they are difficult cause of vacuum, elect and hydraulics depend on each other. get a "Auto Stethiscope",( make sure you have CORRECT cloldcrank Amp Batt or dont try fix anything) listen for HISS leaks thru Vac SYS, ground,circuit faults, even brake pedal adjustment (could stall engine by tellin throttle control sens to stop) ETC ETC ETC Steve (970)310-4494
Sep 21, 2010 at 5:05 PM
SCOYBOY
  • 10 POSTS
HIT CONSOLE W/OPEN HAND-its in the steering/
Sep 21, 2010 at 5:06 PM
