1997 Dodge Caravan
PETEYS
  • 1997 DODGE CARAVAN
Engine Performance problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
replaced timing belt and head gaskets. Positive the timings right. Motor runs but mis fire and doent idle good. Is it possible to be a rotation off in the cams. Doent seem to be firing the front clydinder
Monday, November 1st, 2010 AT 11:21 AM
  • 110,052 POSTS
It wouldn't run if it was 180 ° out. Have you checked for vacuum leaks, has the check engine light come on?
Monday, November 1st, 2010 AT 11:36 AM
PETEYS
No engine lights. Read something about egr could due this. Pulling my hair out. Not much left
Monday, November 1st, 2010 AT 11:50 AM
  • 110,052 POSTS
Remove the EGR and check to see if it is carboned as well as the intake.
Monday, November 1st, 2010 AT 1:31 PM
