alternator problems?
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHADDUKE
So far in the last two days I've gone through two batteries. Two days ago I was trouble shooting a seperate issue, I had swapped out the fuse box located next to the battery, when I swapped that out my seperate issue continued so we knew our problem was the body control module. Well since we put our old fuse box back in we've been going through batteries like water. There's "fizzing" happening on the positive terminal of the battery and just moments ago after my wife needed a jump start the rpm's were going all over the place and randomly the check engine light and other lights were flashing on and off. I wasn't sure if we just need a new alternator or if we messed something up with the fuse box. It seems like an alternator issue but the timing of all of this revolves around the fuse box.
Any suggestions?
Thanks and God bless
Jun 23, 2010 at 7:56 AM
  • 110,251 POSTS
It sounds like you are overcharging the battery, which means a bad voltage regulator. One problem with that is this. The voltage regulator is built into the PCM and is not serviceable. What I need you to do is check alternator output. Follow these directions and let me know what you find.
https://www.2carpros.com/how_to/how_to_test_alternator.htm
NOTE: If you are frying batteries that fast and I am correct, you will need to replace the PCM.
Let me know what you find.
Jun 23, 2010 at 2:02 PM
