1996 Dodge Caravan Engine Backfires
MBEAVY
  • 12 POSTS
I have a 1996 Dodge Caravan with about 140,000 mi. The " check engine" light came on, and ever since this happened the engine is constantly backfiring. At both low sppeeds and high speeds. I don't know what it could be, but I really can't afford a professional mechanic at this time. Please help me as to where I should look to solve this problem.
Dec 16, 2006 at 4:45 AM
BACKYARDMECHANIC
  • 337 POSTS
Without tools and some knowledge it is going to be hard to figure out whats wrong. If you have access to a code scanner run the scanner and see why the check engine light is on. Some auto parts store will do this for you for FREE. If not you could be wasting time and money trying to figure out what is wrong for it could be a dozen different things. If I had to bet though I would say the check engine light is on because your engine is misfiring. The bigger question is what is causing the misfire. Here are a few things to consider. The plugs, wires, ignition coil cap rotor lean mixture, clogged injector(s)/dirty, low fuel pressure, bad valves. ETC,ETC Are you getting the picture. Sorry to say but you need some direction on which way to go and without properly diagnosing the problem you could be changing parts that are good. Here are a few things to consider.
1) when was the last tune up (plugs cap wires rotor) just something to think about.
2) Have the car scanned for codes. this can narrow it down alot. Possibly to the one bad cylinder. You can take it from there. Hope this helps Backyardmechanic
Dec 16, 2006 at 9:50 AM
MBEAVY
  • 12 POSTS
thank you for responding to my problem. I will get my vehicle scanned like you suggested.
Dec 16, 2006 at 10:26 AM
BACKYARDMECHANIC
  • 337 POSTS
Keep me informed, hope it works out and it's not to costly :D
Dec 16, 2006 at 10:28 AM
Suggested Repair
Have the check-engine codes scanned, often free at an auto parts store, before replacing parts. Use the codes to narrow a misfire, then consider ignition items (plugs, wires, cap, rotor, coil) and fuel issues such as injectors or low fuel pressure only as the scan directs.
Conversation Summary
The owner of a 1996 Dodge Caravan with about 140,000 miles reports constant backfiring at low and high speeds after the check engine light came on. The expert says a code scan is needed to identify the misfire cause and avoid replacing good parts, listing possible ignition and fuel-system issues. The owner plans to have the vehicle scanned.
