1995 Dodge Caravan Dies While Driving
KRZY18
  • 5 POSTS
On my way to work the other morning my Caravan started running rough and briefly quit runining. It was as if it was starving for fuel or oxygen. I got it onto the shoulder and popped the hood but did not notice anything wrong, I.e. belts, battery cinnection, leaks. After a minute or two I started it up and was able to make it to work. It did stutter a couple more times. When I fired it up after work it took several trys to get the motor to turn over, as if it wasn't getting any fuel? I should add I put a bottle of "Heat" in the tank because I was suspecting some bad fuel. I "topped off" the tank the day prior to this problem. After finnaly starting, I made it home with no problem. I have a 42 mile drive to work one way.
Mar 23, 2007 at 12:39 PM
BOOTDOG
  • 665 POSTS
first thing i would do is replace the fuel filter and check the air filter. if that doesn't help then i would suspect the fuel pump going bad.
Mar 23, 2007 at 11:38 PM
KRZY18
  • 5 POSTS
Where's the fuel filter located? I hope its not in the tank.
Mar 28, 2007 at 12:19 PM
Suggested Repair
Replace the fuel filter and inspect the air filter. If the stalling and hard starting continue, suspect a failing fuel pump.
Conversation Summary
A 1995 Dodge Caravan ran rough, briefly died while driving, stuttered, and later was hard to start, as if it was not getting fuel. The owner had recently filled the tank and added a fuel treatment. The expert recommended replacing the fuel filter and checking the air filter first, then suspecting a failing fuel pump if that does not help. The owner asked where the fuel filter is located.
