1995 Dodge Caravan why does the radio, interior lights and
136,000 MILES • 6 CYL • FWD • AUTOMATIC
JPWOMACK
hello
i replaced the alternator recently, and now my interior lights, radio and electric doorlocks will not work. i have tested for the fuses and i am getting power. thank you
May 20, 2009 at 5:36 AM
CARADIODOC
  • 34,397 POSTS
Did you check the fuses under the hood? Does the chime work? Also the under-hood lamp? All these things run off the airbag fuse. It's the one in the yellow pull handle in the corner of the fuse box behind the battery. Sometimes those fuses corrode. In my case, someone mis-positioned the wire going to the under-hood lamp and it rubbed against the inner fender where it's attached to the left hood hinge.
caradiodoc
May 21, 2009 at 7:44 PM
