1995 Dodge Caravan When replacing ecm
96,000 MILES • 6 CYL • FWD • AUTOMATIC
FAERO
Car died on a trip. Pulled into parking space went to check the transmission fluid, and it cut out on me. We had it towed to local garage that said the problem was the computer. Could not afford to let them fix it, so we towed it home. Finally bought a new computer (well a used one), same part number and everything plugged it in. STILL NOT WORKING!!! Husband has checked power going to computer, but no power going from computer to fuel pump. Did we do something wrong with the computer, it's pretty much just plugging it up, right?
Nov 16, 2008 at 4:26 AM
BMRFIXIT
  • 19,053 POSTS
Did you check fuses and relays
check ASD relay
and also check for spark
if no spark suspect the crank sensor
on this year is just plug in
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 16, 2008 at 7:37 AM
