Hi my Caravan has been acting crazy, the check engine light came on, the car's engine will rev up then stall at idle or jerk hard while driving. Before all this started the rpm and speed gauge went hay wire but were easy reset by pressing and holding the trip reset, not sure if that has any thing to do with it. Any way I had the check engine light tested and was told my PCM is fired. Is there anything that would cause it to show the PCM is fried on the diagnostic or are they pretty much correct? Please help I have already been "taken" for a fuel pump and don't want to shell out 1,000+ to find out I was lied to again.
Aug 18, 2010 at 9:48 PM
