1995 Dodge Caravan Stalls at Idle
JAMESHAWAII
I have had an ongoing problem with the engine stalling when I go to idle at a stop light. The engine starts back up immediately. This could happen again or might not happen for several weeks. Then lately it started happening worse with always low RPM or deceleration. It seems on high RMP or excelleration there is no problem. This happened after a tune up. So, I believe it is something deep in the fuel, electronic or ignition system.
Thanks
James
Mar 15, 2006 at 10:44 AM
VANDRAGON
  • 298 POSTS
it sounds something like a loose vacume tube or a sensor left unconnected. what engine do you have. there are so many things it could be. i would take it back to whom ever did the tune-up(if it wasn't doing this before the tune-up) and explain the problem and that you didn't have the problem before. if all else fails there is always small claimes court but just asking in a very nice way works wonders. hope this helped!
Mar 19, 2006 at 12:09 AM
Suggested Repair
Check for a loose vacuum hose or a sensor left unconnected after the tune-up. If the stalling started after that service, return the vehicle to the shop and explain the problem.
Conversation Summary
The owner of a 1995 Dodge Caravan V6 reports intermittent stalling at idle and during low RPM or deceleration, with the engine restarting immediately. The issue began after a tune-up and does not occur at high RPM or during acceleration. The expert suggests a loose vacuum hose or an unconnected sensor and recommends taking the vehicle back to the shop that performed the tune-up.
