1995 Dodge Caravan electrical issue
TOM JECKER
Electrical problem
1995 Dodge Caravan V6 Two Wheel Drive Automatic 114000 miles
when engine is cold and headlights are tiurned on all gages go to 0. when lights are off they work just fine.
Dec 5, 2007 at 9:38 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like there is a bad connection at the back of the cluster or the main harness somewhere.Start be checking cannections for moisture/corrosion/ tightness.Probably need to remove the cluster to gain access to the connectors for it
Dec 6, 2007 at 2:39 AM
