HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Exterior Light
Headlight
SPONSORED LINKS
2000 Dodge Caravan low beam lights will not go on either si
CLAYTONBROWN
MEMBER
2000 DODGE CARAVAN
Electrical problem
2000 Dodge Caravan Engine Size unknown Wheel Drive Type unknown Automatic 137000 miles
got in and turned on lights but both low beams will not go on, high beams work fine
Tuesday, January 8th, 2008 AT 12:58 PM
BMRFIXIT
MECHANIC
1st order of Business is check and replace the bulbs
check fuses also
SPONSORED LINKS
Tuesday, January 8th, 2008 AT 1:25 PM
Please
login
or
register
to post a reply.
Related Headlight Content
2004 Dodge Caravan Headlights
Electrical Problem 2004 Dodge Caravan Front Wheel Drive Automatic Why Is There Moisture In The Headlights And How Do I Get Rid Of It
Asked by
buttmuncher
1 ANSWER
2 IMAGES
2004
DODGE CARAVAN
VIDEO
Headlight Bulb Replacement Dodge Caravan
Instructional repair video
GUIDE
The headlight bulb is located inside a water tight headlight lens connected to the wiring harness using a weather tight electrical plug to help repel damage causing moisture...
2001 Dodge Caravan Interior Front Reading Lights Not...
The (2) Front Reading Lights In Ceiling Don't Come On. It Might Only Be That The Light Bulbs Are Dead But I Need Instructions On How To...
Asked by
geowin
1 ANSWER
2001
DODGE CARAVAN
2001 Dodge Caravan
I Have 2001 Grand Caravan Sport And What The Problem Is That Sometime When I Start The Van Or When I Am Driving The Light Inside The Dash...
Asked by
steve60514
1 ANSWER
2001
DODGE CARAVAN
1995 Dodge Caravan Electrical Issue
Electrical Problem 1995 Dodge Caravan V6 Two Wheel Drive Automatic 114000 Miles When Engine Is Cold And Headlights Are Tiurned On All...
Asked by
Tom Jecker
1 ANSWER
1995
DODGE CARAVAN
2000 Dodge Caravan Turn Signal And Brake Light
2000 Dodge Caravan I Have A 200 Dodge Caravan. My Left Turn Signal Works When It Wants To And The Right Brake Light Only Works When...
Asked by
tonya77
1 ANSWER
2000
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Headlight Bulb Replacement Toyota Prius
Dim Headlights Lights - Tesla Only
Replace Headlight and Blinker Bulbs BMW 328i
Online car repair manuals
