Windshield wipers stopped working. fuse is good. There is voltage on the center two pins of plug when switch is on but not on the outside two pins. I plugged in a new mortor and it didn't work either. (motor was not installed.... so not grounded?)
Is this likely a switch issue?
I need advice on properly checking the voltage at the plug so that I can narrow it down to the switch or the motor.
Nov 1, 2008 at 6:35 AM
