2002 Dodge Caravan
DON3343
  • 2002 DODGE CARAVAN
2002 Dodge Caravan 85000 miles
my front wipers come on by themselfes with the key off and the wiper switch off. What would cause that?
Saturday, February 7th, 2009 AT 9:27 AM
JDL
  • 16,098 POSTS
There are several things that might cause it. You may have to get somebody to check manufacturers codes, see if anything pops up.
There is an on/off front wiper relay in the integrated power module. The voltage to both the load and control side of the relay are hot all the time. The ground circuit for that relay goes to the ipm. There has to be a request or the circuit won't ground. The IPM--BCM--front wiper switch--wiring circuits are all involved.
There is a fuse 4, 30amp, if you pull the fuse, it should stop the wipers from coming on, until you can get it fixed.
Saturday, February 7th, 2009 AT 10:53 AM
DON3343
Thanks for the help with my wipers. I should have mentioned I cut the wire on the firewall that controlls the wiper return. Low and varitable speed which solved the problem of the wipers coming on by themselfs but all I have is high speed and I have to time it when I turn them off. I will try your advice and replace the relay. Thanks again
i
Saturday, February 7th, 2009 AT 12:25 PM
JDL
  • 16,098 POSTS
I'm not sure replacing the relay will help, check the relay circuits. I just wanted to add, I think the problem is on the ground side of the relay control circuit, not the relay.
Sunday, February 8th, 2009 AT 8:48 AM
DON3343
I replaced the on/off wiper relay on monday feb. 9 and my wipers have worked fine ever since. I think the relay had to be the problem so many thanks again.
Wednesday, February 11th, 2009 AT 2:05 PM
JDL
  • 16,098 POSTS
I'm glad you got it fixed.
Wednesday, February 11th, 2009 AT 2:39 PM
