1994 Dodge Caravan rain fall
86,000 MILES • 6 CYL • FWD • AUTOMATIC
SMITTY3886
I was leaking water I thought from cooling system...tried some "stop leak" product...worked well for a few weeks...now I have antifreeze flowing from both side of engine...most from the driver side..put on some of those home ramps...hoping it was just a hose...on passenger side it seems to be coming out of...maybe...the water pump...can't really tell about the drivers side...any help out there?
Feb 3, 2008 at 1:29 AM
MIKE H R
  • 3,094 POSTS
without seeing the car I would say the water pump is bad and when driving or the cooling fans come on it can blow the fluid on both sides of the engine. When you put a new water pump in flush the system and replace the thermastat the stop leak could case it to stick if not now later down the road.
make sure it is the water pump check the small hole in the back and when the water pump when thye go bad it usually leaks from that hole.
Feb 3, 2008 at 4:49 AM
2CARPRO JACK
  • 11,533 POSTS
Sometimes the water pump will leak in between the heads in the block and come out the drivers side.There is a hard line with an o'ring runing there over to the top radiator hose.
Feb 3, 2008 at 11:55 PM
