1994 Dodge Caravan gas in oil
BUDCHICFORU
Smells problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic 206k miles
there is gas in my oil/i found 1 spark plug that had gas on it/i change it and van ran fine/but its messd up agine/did not change plug wire or coil/if not plug or coil/what can it be. dont have much monney. thanks.
Feb 25, 2010 at 7:12 AM
CARADIODOC
  • 34,397 POSTS
If you also find an unusually long crank time for the engine to start, you might suspect a leaking injector. The raw fuel will leak out when the engine is off, and run through an open intake valve and past the piston ring into the oil pan.
Install a mechanical fuel pressure gauge and watch what happens after the engine is turned off.
caradiodoc
Feb 25, 2010 at 8:14 PM
